54 Hornet Hollywood stainless strip clips
Hello all I am looking for the 4 clips that hold the ss strips on the cowl on either side of the outside fent door. Also looking for the clips that hold the ss strips on either side of rear post where back window sits in.
The ss strips go on an angle. I also had the valves readjusted and found 3 too tight and some were to loose.Should run better now. Air was ouffing out front carb and longer the engine run it started to backfire out exhaust.
Hudsonly Ray
Hudsonly Ray
