A bit more than I would give but if you need a 308
  • 50C8DAN
    edited February 2014
    Hey the seller says it is rare, doesn't that make it worth big $$$$ :))
  • Based on the trash on the fire wall, I expect that this was home to some local mice. I am with rick, $1500 would be a good price to gamble on?
  • One thing you might not realize is that the "Hash" blocks were all of the "soft" variety.  They were not the chrome alloy material used during step down days.
  • I've heard it both ways.  Some folks declare the '55 & '56 blocks were "soft" are more normal cast iron like Nash used, and I've also heard that the AMC blocks were yet even harder (more chrome alloy) than the HMCC blocks.  I have no idea how one would go about proving either statement at this late date.
  • I have heard this story as well and am somewhat skeptical.  The same story is told about Studebaker engines and again it seems to be a myth.  I am not saying that Studebaker and Hudson engines did not use higher or different Ni and Chrome content but that it was a big differentiator from the Big 3?  The story about the Hudson 6s after the AMC purchase that I heard was that due to valve surfaces cracking the softer cast iron was used, but really???
  • So there are a couple other issues here.  1.  It looks like there is a lot of rust here.  The fan and water pump tell a story.  2. If they are AMC twin h, it is different from the Hudson and you would need both the intake and exhaust to be good. I think the exhause manifolds are succeptable to rusting out.  3.  These had a different oil pan so if you were putting in a step down, you need a pan, and to move the dip stick. 4.  If this has a hydromatic, you have to be able to turn the motor to disconnect the 32 bolts to just pull the engine, and if you pull the hydro with it, the mounts are a bear to get at.  5.  As much rust in the engine compartment, I would say the body is probably bad, and you have to get it up high enough to disconnect the u-joint and trans mounts. Me? with all the work, I would not give more than $200 for all.  You will have at least 5 hours or more in parting out, unless you take the whole thing home.  How do I know all this?  I just pulled the engine from a '55 several months ago.   Two 1 hour trips and about 6 hours later, I had it out.
  • Paul would know.
