Transmission Designation
That's a Hudson built transmission and the 301838 is a Hudson p/n. If you want a gasket set, I'd suggest Dale Cooper or any retailer that sells Best Gaskets like Olsen's Gaskets in Port Orchard, Wa., for instance. Order by Make/Yr/Model.........unless I'm wrong.
F0 -
There are several people in the Hudson Club that have significant Hudson Transmission repair experience. These folks would know where the required gaskets can be obtained.Al Saffrahn in Arizona, Doug Wildrick in Indiana are both in the Hudson repair business and do transmissions.0
this is a ebay site selling a compleet gasket set for t86 trans with od that is what a 48 to 51 hudson single leaver trans is a t861
OK. Somebody feel free to straighten me out on this one. Was I dead wrong? That's something I don't want to be. I don't want to be wrong, either.
F0 -
Hi Frank, You are right. T-86 Borg Warner trans used in many cars of the 50's and 60's.
T-96 light duty version used by Hudson Jet, Ramblers etc.
Single lever Hudson-1941 -early 1952. Hudson built.0 -
RICK AND FRANK THE 41 TO 47 SINGLE LEVER TRANS IS A DIFFERENT TRANS THAN THE 48 TO 51 SINGLE LEVER DIFFERENT GEARS AND SINCRO'S 48 TO 51 IS A BETTER SMOOTHER TRANS THAN THE EARLYER VERSION0
Borg Warner Gurus:
Northwest Transmission
13500 US Rt.62
Winchester, OH 45697
937-442-2811
fax 937-442-6555
Contact: Rusty
Not going to explain how I know this, but $3000.00 and 3 weeks at a trans shop on a 54 Hornet, ought to tell you a little.
BW's used by Studebaker, Packard, 50-70's Jaguars, & Hudsons0 -
OK. I'm not nuts.
Weird Al's song "Everything You Know is Wrong" has been going through my mind for the last 24 hours.
True that changes were made along the way, but still a Hudson built trans 'til mid year '51.
F0
- 120 Hudson 1916 - 1929
- 612 Vehicles
