Are these Hudson Pullers ? need ID help
I'm cleaning out my excess tools and came across these pullers. They are either Hudson or Nash I believe.
The J 1270-N-1 is a steering wheel puller , 4" deep , the U shape collar is 1 3/4" across , the height of the opening is 3 1/4"
It has a bushing to go in the opening for the horn wire ,Seems like I remember using this on a Hudson wheel
The J 678-A-1 looks like a hub/damper puller . 8 1/8" across opening , 2 1/2" deep , looks small for Hudson ?
I'd like to sell these, I don't use them , but would like to know what they fit.
Any ideas? Google search didn't help with numbers , but I'm not real good at it/
Thanks
The first item can be used to pull steering wheels from cars that have steering wheels like the 48-9 Hudsons ( actually used on some 50 models as well.) The second item is a harmonic balancer removal tool.0
Here are some photos in action of the steering wheel puller.
Thanks Lance , I knew that probably was a Harmonic / damper puller , just not sure if it fits Hudson.
I don't have one to measure. I probably used it 35 years ago.
Go to the H-E-T website and look under "Manuals" ("Old Site").
Click on the "Manuals" for different eras.
You'll find several Kent-Moore catalogs showing all the tools they made for Hudson, listed by part number.
Thanks Jon , but I'm not registered there. This is my Hudson forum of choice.0
Hello "lostmind,"
I checked my Kent-Moore SERVICE TOOL GUIDE 1952 Edition for HUDSON catalog. This is what I was able to find out about your tool numbers as best I could:
Your first tool, 1270-N-1 strongly resembles the illustration in the catalog for the NASH J-1270-NA (all series thru 1948). So, my guess is that it indeed is a Nash steering wheel puller.
Your second tool, J-678-A-1 strongly resembles the illustration of J-676-C which is a Hudson vibration damper puller for HUD - 1936 - 52 (8 cylinder?) all models.
Well, there you have it. Maybe someone with a bit more Kent-Moore knowledge can provide more information here.
Dan
Thanks Dan , I appreciate the efforts. I suspected Nash because I cleaned out a Nash dealer years ago.
I'm pretty sure I used that puller on a 49 Hudson wheel. I made a split collar from a black pipe reducer
from a hardware store. I can't find it now.
If some one needs these pullers , the steering wheel puller is $35 ( sale pending)
and the Damper puller is $25 ( available 11/12 )
Plus $12.85 shipping
Send a PM
Thanks
Roy
lostmind, you can also access the online library, that Jon mentioned, directly by using this link:
http://hetclub.org/burr/lithomepage.htm
Alex Burr
I would be interested in the steering wheel puller...130983855510
Thanks Alex.
The steering wheel puller has been sold.
The dampner puller has been sold--Thanks0
- 104 Essex Super 6
