Brake and Clutch toe board seals
Not to undermine Wildrick Rubber in any way, but I'm not sure they carry these items. I could be wrong though!
In case they don't, I've used these before. They are a little bit smaller than original, but still work fine nonetheless.
http://www.kaiserwillys.com/product/960/willys-jeep-brakes-linkage-parts-accessories
Just to maybe add a little clarity. I believe the parts that Doug Wildrick sells are the thick 'inside' clutch and brake toeboard seals. The link I've listed above are parts to replace the 'outer' clutch and brake toeboard seals that use thinner rubber, metal washers and springs.
If Wildricks toe board seals are the same that Kgap had, they are thin in the middle with a thicker outer lip that keeps the washer in place. That is the type I bought from Kgap many years ago if memory is correct. Also, I believe I followed a suggestion from Bill Albright and installed springs used behind door panels for inside door handle or window crank handle. Don't remember which one or if they are both the same springs.
Maybe Doug will let us know more about them.
Lee O'Dell
