Throttle connections
I took a picture of the connection between the rod that connects to the carburetor and the accelerator pedal rod at the top of the middle of the block so I would be able to put it back right once the engine came back from the shop. The problem is that I didn't take a picture looking from the carb back to the connection and now I can't figure out how to connect the small spring with hooks on each end that is attached to the rod that goes across the top of the head. Can someone post a pic of how that spring is connected?
Never mind. I figured it out by myself.0
