6volt positive ground
Yes Sir !
Okay then it makes sense then0
Thank you0
Actually, to be rather specific, the battery cable runs from the the negative terminal on the battery, to the starter solenoid terminal. The ground strap runs from the positive battery terminal to either the frame, or some part of the engine (like the generator clamp bolt). Then, a separate ground strap runs from the transmission or bell housing, to the nearby cross frame member. Thus: two ground straps, one for body, one for engine.
Hi Jon have the one from the bell housing done just putting on a elec. fuel pump for priming .Not ready to do the wiring yet but thanks0
You betcha, Chip! Will look forward to seeing this baby on the road! Elec. pump's a great idea, let us (CBC) know what brand name, and how happy you are with it.
