Alignment specs
54Hollywood
Hi everyone,
Bought some new radials for our '54 Hornet and I'd like to get an alignment but I don't have the specs for radials. Any help is always appreciated. (I could probably use a good alignment for my back too). :-) Thanks.
Tim in WI.
As far as I know, which isn't much, there are no alignment specs for radials on a step-down. Use the alignment specs that are stock for bias plies. You might want to use slightly less caster with the radials to keep it having too much over-steer. The stock caster angle is pretty marginal anyway, due to the superior design of the front end. Basically, it's a set it stock and road test. Adjust accordingly. Your toe-in and camber angle should be the same as with bias tires. It would be noteworthy to document your results and post them here on the forum.0
