fuel guage interface module allows any fuel gauge to work with any sender unit
12V negative ground only --------
http://www.speedwaymotors.com/Garage-Sale-Fuel-Gauge-Interface-Module,139811.html
Convert any ohm range sender to work with any ohm range fuel gauge!
Fuel level gauges are designed to work with a specific ohm range.
Different automobile and gauge manufacturers use different ohm ranges
to correctly operate their gauges. This can cause problems for a person
who is updating their vehicle with new gauges or a new gas tank and
fuel sender.
This module will allow you to use your stock sender with any fuel
gauge and vice versa. No longer do you need to drop your tank to change
or customize your sender or re-calibrate your fuel gauge. With this
simple device you can ensure your gauge is accurately reading your fuel
sender... and more!
- Reads any fuel sender
- Works with any fuel gauge
- Eliminates fuel gauge needle bouncing with anti slosh technology
- Low fuel level indicator wire for modern gauges with a low fuel warning light. Or add your own.
- User sets empty and full
- Module requires 12 volts to operate
- 3-1/2" wide x 2-1/2" deep x 1-1/4" tall
