where to install amp gauge
Lift the wire off the "B" terminal of the voltage regulator that comes from the starter solenoid. Connect this to the ammeter, and then take a wire from the other side of the ammeter back to that same "B" terminal on the regulator. I can blow up that section of the wiring diagram if you want and email to you.
Geoff0
