3 on the tree column parts find
hudson52sam
where can ya find the three on the tree shifter parts, mines been getting warn for awhile getting stuck in 2 gears more frequently?
Go to my website http://hudsonrestoration1948-54.com/Transmission.htm Select - handi shifter adjustments Note you must replace worn parts to get full benefit. Rubber shift bushings are available from Wildrick Rubber Products. There is a roll pin inside the handi shifter column linkage that needs to be undamaged too. Good luck0
Thank you0
- 182 The Flathead Forum
- 611 Vehicles
