12v conversion
The ballast resistor is built into most "12 volt" coils. Most if not all coils are 6 volt coils and work on 12 volts because the resistor is used. Keep your good OEM coil and add the resistor. Hemming motor news article on ignition coils hemmings.com/magazine/hmn/2006/06/Ignition-Coils/1280615.html0
