Will this work in your Hudson? OD trans at AACA forum
Not Mine -
Studebaker overdrive , looks same as two lever Hudson
Maybe a moderator can get it to stick?
Can you give us a hint as to where to find the discussion, at the AACA forum? Which category?
The mechanics and the OD pieces of some stude transmissions are the same as Hudson. BUT, the external housings are usually different so they are not directly usable.0
Adjusted the post, to point to the thread at AACA (I think that is it).The transmission is also shown on craigslist - http://dayton.craigslist.org/pts/5431114039.htmlContact 'Pat' - (937) 581- seven two eight zero
That's it Rick. Not sure why I can't get links to post here. They work at other forums.0
Input shaft is different from Hudson. (clutch splines)0
- 104 Essex Super 6
