Door striker guide for 33
33kc1989
I'm looking to see if anybody knows if and who might reproduce the guide for the doors on my 33. I guess possibly other makes could fit. I would even go with used also.
Back to the top. Still looking0
PM me, I think I know a source for these.0
Sweet will do if I can figure out how to pm0
To PM:
1. Click on the blue "handle" of the person you want to PM. (Your handle is 33kc1989, for instance).
2. The next screen that opens will be the person's personal page. Look for the small "MESSAGE" box at the upper right side of the page, and click it. A new box will open, into which you can type your message to this person.
3. When done, click POST MESSAGE at the bottom.
4. Do NOT put your message in the box under the word ACTIVITY.
Back to the top0
LOTS of parts such as this were outsourced, Check early Ford parts catalogs, Ever look at your emergency brake handle?, Guess what , Its the same as a Model A Ford. !!Surprise!! I found several things that interchange in the 50 yerars I had my Terraplane Eight.0
I Checked the early ford stuff, close but not quite0
34 or 35 or 36 doesn't work?0
Close but hole centers are off0
Sure worked for me, but of course you might just to make them work, maybe not exact, but if you don,t have one, what you gonna do. Never said 34,35 or 36 were the same.0
Never said you did.0
Are the hole centres for 34/5/6 off by much? Can the holes in the pillar be filed out? Does the fixing screw have a hex nut behind it or is there a cage nut or welded nut inside the pillar?Can the holes in the 34/5/6 guides be welded closed and relocated?I very much doubt that anyone repros genuine 33 door guides, the market for anything specifically 33 is very very small.0
Before doing all the above all I've put out there was to see who or what nothing else. Im aware of making something work that don't quite fit.0
Back to the top0
Found a box of bits and pieces with a few guide wedges from that era, what hole centres are you looking for?0
1.275 overall is 2.2750
Still looking for 1 more0
Back to top. Also looking for female that bolts to jam0
- 92 Essex Super 6
- 573 "How To" - Skills, mechanical and other wise
- 178 The Flathead Forum
