witch cam shaft
dlydonmn7fav
i have 2 new cam shaft one is a clifford lift 372 int 372 exh, 254 duration int - exh
iskenderian lift 437 int 437 exh, 262 duration int - exh the motor i am build is 1955 308 ,030 pistion 262 head ported a little more releaf maas timing chain twin H and header full flow oil filter. i know the isky cam will idel a little rouf but wil it be streetable in town and highway has any one put this cam in a driver not a drag or race car looking for fun and driveabilty. Thanks
i for got im puting 7x large velves0
I didn't know witches had cam shafts. Another occult fact that is not well known.0
For sale, one supercharged broom, hot cam, headers, streamlined handle, super-slick bristles. Apply Badjelly the Witch.0
Actually the Isky race cam will work nicely with the auto trans. The problem many run into is the carb factor. Will not run correctly with your stock WA-1's unless modified to accept larger venturi's. Will idle nicely around 700 rpm. Randy
