Starter question
I took my truck apart a while ago and forgot the starter hook up. I have a 232 motor. My starter has 3 terminals on it, on the solenoid one terminal is strapped to the starter. Next is a small terminal and the other one is a little larger. I need to know where to put the battery lead on, the wire from the starter switch and the lead to the fuse block. My truck is still a 6 volt system.
Assuming you have a standard factory solenoid the battery connects to the large terminal on the solenoid opposite the terminal strapped to starter. The small one at the top is for the starter switch.0
