Need help removing lock cylinder - 1939
I have a 39 Hudson series 91 and need to remove the ignition lock cylinder.
Most of the key is still in the cylinder, and I have the remainder of the key.
The broken stub of the key can be used to turn the ignition onand off. If I
had the cylinder out I think I might be able to remove the remainder of the
key. The appears to be an extra ignition key to be used if I can remove the stub. Thanks for any advise you can give.
David
David
IL HAVE A COMPLETE 39 IGN SWITCH WITH ARMORED CABLE AND COIL INTACT, i MIGHT HAVE A KEY FOR IT OR YOU CAN HAVE ONE MADE, WILL TAKE 40. FOR SWITCH AND COIL, albrighthudsons@msn.com0
