TORQUE SPECS 232/262/308 engine bolts
I would like to know where to find all the specs for retorqueing all the following; please someone post appropriate values for each of the following:
original main bolts 1/2" dia
iron head bolts 7/16" (grade 8 replacement)
original rod bolts
3 oil pump bolts 3/8"
front motor mount plate 3/8"
timing gear sprocket 3/8"
oil pan bolts 5/16"
timing cover 5/16"
camshaft retainer bolts 5/16"
valves access cover bolts 1/4"
3 rear main upper bolts 1/4"
thanks
original rod bolts
oil pan bolts 5/16"
timing cover 5/16"
thanks
54 HSWH wrote:I would like to know where to find all the specs for retorqueing all the following; please someone post appropriate values for each of the following:
original main bolts 1/2" dia 75-80
iron head bolts 7/16" (grade 8 replacement) 75-80
original rod bolts 40-45
3 oil pump bolts 3/8" 20-30
front motor mount plate 3/8" 20-30
timing gear sprocket 3/8" 20-30
oil pan bolts 5/16" 15-20
timing cover 5/16" 15-20
camshaft retainer bolts 5/16" 15-20
valves access cover bolts 1/4" 10-15
3 rear main upper bolts 1/4" 10-15
thanks
Figures inserted above.
Geoff.0 -
Buy yourself a Mechanical Procedures Manual from the club store. Torque specs for everything are inside the back cover.0
