308 roller timing chain/gears
Hello All,
Some time ago I purchased a modified pontiac timing chain/gears from randy at 21stcenturyhudson. Just now I am getting around to installing it. I have evidently lost the instructions as to it's installation. The 21stcentury website is not available at last check. Does anyone recall the proper installation? Cam gear-to-chain is a given, Crank gear-to-chain is also a given. There are 3 keyways to locate it to the crank (probably from pontiac application). Which should be used? Thanks, Mike
e-mail randy [email="maasfh@ntslink.net "]maasfh@ntslink.net [/email]0
Email Randy at [email="maasfh@ntslink.net."]maasfh@ntslink.net.[/email] Of the three keyways, use the small circle that is on the crank gear for straight up. The key with the belved side goes to the right. Match up the red paint to the markings.
Email randy or call 309-968-6157 to confirm
Website has a domain issue and should be up anytime
russ m0 -
Thanks, Russ. Mike0
- 120 Hudson 1916 - 1929
- 612 Vehicles
