49 Commodore rubber parts
I used K-Gap rubber parts for my 1949 Hudson Commodore with excellent results. You will find almost everything rubber has rotted. You will need the door weather seals, the trunk seals, the pads under the rear tail lights, Trunk Handle Pad, the seal around the cowl vent, and even the splash guards behind the front wheels. You will also need a new rubber seal for the rotating antenna that mounts through the roof. You will also need to check the window channels and the window anti-rattle trim. The best source for this material, including clips for the door panels, is Restoration Specialties & Supply Inc at 814 467-9842 or their website at http://www.restorationspecialties.com
Good Luck
BST RGDS
GARY ( happychris )0 -
ILF YOU ARE ON THE WEST COAST, WE HAVE ALL THE WINDOW CHANEDLA AND RUB RAILS, albrighthudsons@msn.com0
