\'36 wheel trim photo?
All may disregard ... I found a negative of photo I took in '90, which I believe shows the needed detail. And our reliable HET Librarian is looking for a backup photo.0
If you're stuck I have a '36 H8 64 series with the original brown paint including the details you are seeking on the wheels. I could measure this to the relevant points for you if necessary so you know the exact thickness and spacings of the pattern, or photograph with a tape measure for the scale.0
Thanks, but the need has been filled ... photo I found in my archives turned out to be an excellent reference, and I also got some good ones from the HET Club Library.0
- 117 Hudson 1916 - 1929
- 98 Essex Super 6
