Alternator diode
Already has diodes. May have one bad. BK.TN0
Some times when using an alternator in place of a generator, the engine will continue to run, after the ignition switch is cut off. this is because of feedback from the alt., to the switch. JC Whitney sells a diode that you mount into the system which prevents the engine from continuing to run. Speedway Motors....<speedwaymotors.com>..
..shows the diode on page 130 of its street rod catalog. $17.950
