snapped handbrake return spring clip
Had the Hornet parked in the street with handbrake set while I did some chores and upon return to move the car I noticed a long spring and attached metal tag sitting on the ground in front of car. Found out this was return spring for handbrake when I released brake and had to push it in to its resting position. Under the car I saw where the body clip welded to rear floor pan had snapped clean off sending the spring shooting toward front of car. I plan to re-anchor this assembly using a flat piece of steel and bolt through floor pan.
I figure I can operate the car safely until I make the fix. As far as I know, the only purpose of this spring is to take the slack out of the handbrake cable when the brake is released. Have I got this right? Don't want to have a bad day out there driving my Hudson. Thanks for your help. ArtS
Art,
I believe you're exactly right. This spring simply removes the handbrake cable slack. You could always 'make' a temporary anchor with something, or add a longer spring. On my car, I couldn't find a spring long enough at the hardware store that was the 'right' strength, so I'm just using two springs in series to do the same thing. Good Luck.
Doug0 -
hudsonguy wrote:Art,
Doug
Thanks, Doug. As you did, I too went to Sears hardware and picked up a few springs that when hooked in series may match the length/strength of original part. I may rig them up to the frame if I decide not to drill a hole in the floor plan.0
