Speedo cable
You need to undo the cable from the speedo head, and manually check that the speedo does not have a bind. If it is tight to turn, it needs overhauling and lubricating. If it turns freely, the problem is most likely a kink in the cable and sheath, or maybe just needs lubricating.
Geoff.0
