Thermostat
There are two types of outlet on 212 motors, depending on year model. If you have the tall type with the by-pass back to the block for recirculating, then you definitely need the tall type thermostat that fits right up into the neck of the outlet. If you have the smaller necked type then you can use a choke type or conventional squat thermostat.
Geoff.0 -
Thanks Geoff
I have the smaller one so i will try the small thermostat.
thanks0
