29 Essex Pan gasket
Have you tried Dale Cooper? (He advertises in the WTN)0
http://www.olsonsgaskets.com/inquiry.html
There are some great people here. I got my 29 Hudson gaskets for them. Thanks Ron0 -
Dale Cooper sell the same gaskets at the same price as does Olson's. Why not give the business to a Hudson guy to say thanks for helping!
http://www.hudsonmotorcarco.com/0 -
P.S. ther is no real main seal on a 29 Essex,. There is a slinger on the back of the crank. The oil is slung into a set of sheet metal peices with a cork gasket which seals it agains the block. The front is sealed by a felt timing case seal. Other than that these is some rope seal whcih seals the main caps to the block...not the crank0
