Twin-H Question- Will 1955 Unit work on 51,52,53,54 Models?
niels, i believe the 55 and 56 manifolds are the same (i.e. with the intergrated tube). you need the exhaust as well as the intake. The castings are completely different and will not mount together with the 52-54 exhaust but as a unit can be used. The stepdown linkage definately works with the hash set-up though your exhaust will require adaptng. The hash exhaust outlet is at a different angle, tighter to the manifold, the flange is indexed differently and it is 2 1/4".0
nick s wrote:niels, i believe the 55 and 56 manifolds are the same (i.e. with the intergrated tube). you need the exhaust as well as the intake. The castings are completely different and will not mount together with the 52-54 exhaust but as a unit can be used. The stepdown linkage definately works with the hash set-up though your exhaust will require adaptng. The hash exhaust outlet is at a different angle, tighter to the manifold, the flange is indexed differently and it is 2 1/4".
Thank you for the info~!0
