Air Conditioning in my Hudson?
Okay, what all do I need to do to add air conditioning to my hudson?
just thought I would ask to get some ideas...
might be dumb, but I got a new compressor and clutch from a late 70's early 80's GM that is dry and never had oil or freon in it.
Is this a starting point, or should I just scrap this idea, and look at vintage air?
I guess the biggest problem is finding the crank and water pump 2 groove pulleys....
anyone have some ideas?
hudsonkid wrote:Okay, what all do I need to do to add air conditioning to my hudson?
Just scrap this idea, and look at vintage air. Unless old parts are rebuilt (well), why put used mechanicals on your car that may soon fail. I assume you want to install A/C that will actually work.:rolleyes: Although I forget who is reproducing the compressor bracket, there are gurus on this forum and in the HET club that know where to get them. Last time I heard, the price for one was a wopping $175.00! You will also need the double crank and water pump pulley. Those should be a joy to find. Would you consider putting in the Vintage Air unit that goes under the package shelf? That was the location (of evaporator and blower) back in the day. Or, you could get yourself a Swampy (the A/C model, not the evaporative cooler type) and give that a whirl. :cool:0 -
Those old systems are made to run with R12 refrigerant which - at least here in Washington you can't buy anymore...
Vintage Air seems to be pretty popular
http://www.vintageair.com/
Hot Rod Air looks very similar but they have a dual evaporator system for front and rear cooling.
http://www.hotrodair.com/dualevap.htm
Southern Air - I don't know anything about these guys...
http://www.southernrods.com/categories/heating-and-cooling/heating-and-cooling-systems/southern-air-1.html0 -
anyone have some ideas?[/QUOTE
I have hands on experience with both Hot Rod Air and Vintage air. My 49 Super Six has Vintage air. The original harmonic balancer was machined to remove the original wide groove. A double sheave was bolted on the front of it. The water pump pulley is from a junk yard..single goove to narrow it up to fit the narrow GM alternator and belt. The comprssor mount is home made. The stock heater and part of the plenum above it was removed. The Vintage ait has it's own heater and defroster. The original fan is in place and the air has been working flawlessly for several years.
The 54 Hornet has Hot Rod air. I found that Vintage was a bit arrogant and slow to respond, so I went with Hot Rod.They were great to deal with. I was lucky enough to find a Hudson double pulley for the engine drive. (This car has factory PS also.) I made a mount for the compressor that mirrors the PS pump mount. I used the two universal brackets they supplied and welded up flat plate to bolt under the head bolts. I didn't use the Hudson double fan pulley that requires a longer water pump shaft. I used the stock Non PS water pump and got a double pulley from a junk yard that worked. I think it came off a Dodge Dakota 6 cyl.. Not sure. The units Hot Rod and Vintage are very similar. The heater and plenum where cut out to make a fit. The 54 was a bear to fit inside that smaller dash !!!! The glove box was also altered to allow the vent hoses to fit.
Both cars have GM 12 volt alternators and the mounting brackets were fabricated using a welder and the old generator mount.
The Sanden compressor is a honey..no vibration! Yes it uses 134 freon too.
On a scale of 1 to 10.. It's an 8!
Good Luck,
Dave W. Fl0 -
Save your self some headaches.
Even I, the King of Scroungers of used parts, will tell you GO WITH A NEW A/C KIT.
I know the owners of both Hot Rod Air and Vintage Air and live here in the same city as they do. I have personally installed and used both company's units in my vehicles. They are both reputable people and build excellent units WITH warranties. David Stutts, owner of Hot Rod Air would problably respond quicker if you have questions or problems than Vintage Air would. I like them both but this is a fact. I think Vintage Air has gotten so large that they are hamstrung by their company's size. Still a great unit though. A nice little feature of the Hot Rod Air unit is that if for some reason the blower motor failed it can be removed without removing the complete unit. The unit stays in place and the motor just drops out from below.
The Sanden compressors are the greatest for dependablity and besides that they look nice. Another thing is to go with the biggest and best unit you can afford such as the "Elite Series". Whistles and bells are nice too and if you are married this goes a long way with creature comfort for the misses. When you get to your destination everybody is happy.
Super Dave's comments are "Right On!"
Peace,
Chaz0 -
I added the Vintage Air 'Slimline' self-contained evaporator unit which fits under the dash of my '49 perfectly. I had to remove the ashtray. It's tucked forward as much as possible, and you hardly notice that it's there. I was also able to retain the stock heater with no changes. I ran the lines thru the top left corner of the removable floor pan (just above pedals) to the drier mounted on the inner fender (above driver's wheel area), and the compressor which is above the alternator, next to the battery. I was also able to buy a compressor from Vintage that had the wide (5/8") belt pulley, so I drive everything with one wide belt. No slips or squeaks, runs smoothly, never needs adjustment. I had to make a bracket (3/16" steel) that tied into the two left front head bolts (around the thermostat) and at the bottom is sandwiched between the alternator (which is in the stock generator location) and the block. Vintage has a bracket available that mounts the compressor to this bracket. This is where I added the fore/aft adjustment slots in the larger bracket. Then I ran the lines from the compressor underneath the battery cage up to the horizontally mounted condensor in front of the radiator. This way the lines and compressor avoid all of the heat on the right side of the engine. I did this two years ago, and the Vintage Air total was around $1100, as I recall. It's an R-134A system.
I think the installation came out pretty clean, but the best part is how well it works, you'll never regret adding it. Now when I go to cruises and shows with my friends, everyone parks their Brand X rods and want to ride in the Hudson with the A/C blasting.
I thought I'd taken some pic's, but can't seem to find them at the moment. Are you coming to Kearney? (I'm headed there via California, my Hudson is the 'Just Married' Car in a wedding next Friday in Palo Alto!)0 -
I installed Southernrods "Southernair" in my 46 came with everything but the gas. had choice of r-12 or the new stuff I opted for the new. came with brackets too! but mine has been rodded...works to good, my wife sets on passenger side and freezes her legs off..was $575 about 8 yrs ago..
GOOD LUCK on your choice. I think all 3 are good from what I here, just use who makes what you want!0 -
The repro ac bracket is sold by Joe Stinnett, HET Eastern Region Director
Something else to consider: you can run AC on 6volt. Most compressor clutches will engage with 6 volts applied to them. If they don’t you can reduce the air gap in the clutch to the minimum clearance and they should engage just fine. The only other item which would have to be 6 volt is the fan. No bigggie there either.
You can also find an evaporator which will fit into the existing Hudson heater box. You then can use the defroster outlets on the box to attach remote ac outlets. If you still want to use your defroster…a good idea.. insert “Y†fittings in the defroster outlet hoses. Run one side of the “Y†to the AC vents and the other to the defroster.
Now I know this will spark all sorts of conversation about electrical capacity, durability etc. but it does work and you can make a choice as to converting your car to 12 volt or not.
Sorry for the long post, but here's some information for you.
I'm an automotive air conditioning geek. I've been fooling with it for a few years now, enough so that I have an EPA section 609 certification to buy R-12. The short answer to your question is to go with an aftermarket kit such as Vintage or Hot Rod. Take your new old stock compressor and sell it on E-bay to offset some of the costs. But, if you're a masochist or a spendthrift, and I have been accused of both, you can make your GM-powered custom setup work, and work rather well.
My advice is, whether you use your GM compressor, or an aftermarket setup (actually, especially if you use an aftermarket setup), do * N O T * use R-12. Most aftermarket systems are designed to work with either R-12 or R-134a. Go with 134. It's cheap, readily available, safe to both you and the environment, and performs well. Yes, R-12 is a superior refrigerant to R-134a. In comparison to 134a, R-12 has a better thermodynamic profile and operates at lower head pressures for a given volume. But, on a good system, using 134 instead of R-12 will only lose you a couple of degrees performance as measured at the vents. A practical scenario: If you're putting your system together, and you accidentally cut an O-ring, you would rather be out 20 bucks on losing a 134 charge than a couple hundred on an R-12 charge. Or, if you have a problem down the road and have to tear the system down, R-12 isn't getting any cheaper as time goes on and supplies dwindle. Options? Pay the price, or break the system down and convert it. I can count on one hand the number of times in recent years I have used R-12. I ONLY use it in instances where a good functioning R-12 system is just a bit low on charge (and not substantially leaking) and converting it to 134 is more trouble than it's worth. Such was the case with a 1963 Cadillac Coupe De Ville I worked on. Every vehicle that has come to me with a failed or leaking system I have converted to 134, and I've always had good results.
Just for information's sake, There are a number of alternative refrigerants out there that claim superior performance to R-134a. Probably the best one is a product DuPont invented called MP-52, however to my knowledge it is not currently manufactured. You'll also hear about Freeze-12, made by Johansens. I've personally never tried it, but looking at the MSDS on it, it's a blend of about 80% R-134a and about 20% of a very similar refrigerant, with the ASHRAE desgination R-142b. I would expect it to perform much like 134. Then there's R-12a. Note the "a". This stuff is basically propane. It does work and I have installed it before. But I don't use it anymore, because it's, well, FLAMMABLE! It has an odorant in it, Ethyl Mercaptane, which is the nose-wrinkling-rotten-eggs-smell found in natural gas. This is so if your system leaks, you'll know. From experience, its performance is not much better than 134; certainly not enough to offset the safety concerns.
If you use your GM compressor, it will operate FINE on 134. Make sure there's no mineral oil in it from the factory. If there is, drain it. When you put your system together, there should be a sticker on the compressor that tells you how much oil to use. Use that amount, but don't use mineral oil; the lighter 134 molecule will not carry it through the system. You'll need to use either Ester 100 or PAG 150. Pour half the required oil charge into the compressor, and the other half into the receiver/drier. Lewis is correct about the clutch; it should engage with 6 volts applied, and if it doesn't, get yourself a clutch installer tool and reduce the gap between the clutch pressure plate (the outermost part) and the pulley until it does. Just make sure the pulley will still free-spin with no power applied. You're going to need in addition to your mounting setup and pulleys a condenser, evaporator, receiver/drier, and a manifold hose set, as well as assorted A/C O-rings. And you'll need a low pressure cycling switch to install into the receiver/drier (a few bucks) wired in-line with the power lead to the compressor clutch. These parts that you buy new, such as the hose kit, are usually designed to work with either refrigerant. You need to use the largest (physically) condenser and evaporator you can fit in there. More surface area = more heat transfer = better performance. When the major auto manufacturers switched to 134 (for GM it was model year 1994) the way they made up for the performance difference between 12 and 134 was to increase the system size-- condenser size, evaporator size, and hose diameter. In most cases the compressors were the same ones used the previous year for R-12, filled with a different oil, with a different sticker applied!
When you go to charge the system, buy, beg, borrow or steal yourself a vacuum pump and a set of manifold guages and vacuum the system down to as close to 29.92 inches (this is at sea level, subtract 1 inch for each 1000' elevation increase) as you can get for about an hour. Then unhook the pump and let it sit a while with the manifold guages still attached, and see if it leaks its vacuum. If it does, start fixing. If it doesn't after 30 minutes or so, charge the system through the low side service port (for GM systems usually located on the receiver/drier). You're going to have to guess on how much to put in because you're not using a system that was designed for a particular automobile with matched components. I'd have to know exactly what compressor you have to make sure, but a good heuristic would be to charge to a reading of about 225 psi on the high side, and 25-35 psi on the low side, with the clutch engaged of course. It'll probably take about 3 pounds of refrigerant.
Another point to consider is, the better aftermarket systems come with Sanden compressors. These things are GREAT. They come stock on DaimerChrysler vehicles since about 2002. They last longer, are lighter, require less horsepower to operate and are capable of sustaining higher RPM operation than your GM compressor.
You'll have to look at the dollar figures, and see if it pays you to build your own system, and consider if you've got the equipment, time, and patience to do it. Let me know if you need any advice, and how it works out.
Just for the record, my Hudson is a '29, and doesn't have air.
Best Regards,0 -
James...Excellent Information!
You've convinced me to go aftermarket!
I've been eyeballing the Hot Rod Air Dual Evaporator system now I know thats what I'll get!0 -
wow...
thank you everyone so far for the terrific advice.
Without a doubt, i would keep it all R-134a, an R-12 wasn't even a consideration.
as well as 6 volt.
Thinking about it now, perhaps the GM R-4 compressor is not that great of an idea. I bet if I look hard enough, I could find something later model that has R-134a and pick it up cheap.
Still in the planning stage, and thinking stage, it would be nice to figure it all out, and be able to cruise around with the windows up...
One thing for sure, I got to make sure I got the car running at a constant cool temperature before I start adding items to make it run any hotter. I have been thinking about an auxillary 6-volt fan up front.
this is what makes the forum great, all of the ideas that come out when you ask the question..0 -
rambos_ride wrote:James...Excellent Information!
I JUST RECIEVED MY A/C UNIT FROM HOT ROD YESTERDAY, CAME IN THREE BOXES AND I LIKE WHAT I SEE...GOOD LUCK...RAY0 -
okay, looking at some of the units from the links that Rambos posted, are some of these units self contained, and require no compressor mounting?
maybe I was not understanding it well enough...
but if that were the case, a self contained unit without worrying about pulleys, etc... would be great...0 -
I am a bit of a purist so I understand staying 6 volt. Do yourself a favor though and buy an Optima battery if you haven't already. And put on some grouesome battery cables; I use 00-guage 1320-strand welding cable. Flexible as a rope.
Either a good performing mechanical fan with a shroud around it or an auxillary electric fan (or both) is a great idea. I believe there are some aux electric fans out there for 6 volt.
Make sure when you put things together that you mount the condenser in FRONT of the radiator. You want the oncoming air to cool the condenser first, then the radiator. If you want things to really perform you can get some light guage sheet and shroud everything so all the air coming in the front of the car has to pass through the condenser & radiator.
If you're interested in learning more about this stuff, Haynes makes a GREAT Techbook on Automotive Heating & Air Conditioning. You can pick it up wherever Haynes manuals are sold, such as Advance or Auto Zone.
Best Regards,0 -
I've been a licenced refrigeration mechanic for 37 years, had my own business for 20 years now. My advice is that you purchase a good new system and bolt every thing on properly. I wouldn't shroud it in front unless you have a good electric fan as you will lose surface area on your rad. Although an electric fan is ,in my mind, mandatory for those really hot days and/ or when you're moving slow. Then take it to a good refrigeration shop or automotive shop who specialize in auto a/c. They can leak check the sytem for you, install the right oil , evacuate and charge the system properly for you. Won't cost that much and you know its done right. Just as a side note . Its been my experience that an auto shop will charge outrageous amounts compared to what I charge for doing the same thing. They seem to think its rocket surgery and its not. My 2 centavos worth.....Jim0
Perhaps I should have made myself a bit more clear. By shrouding it up front I don't mean closing the radiator down to the diameter of a front-mounted fan, as you would do in the rear, but instead installing some simple panels around the perimeter of the radiator to keep air from escaping around the top, bottom, and sides. Force more of the air coming through the grille to go through the radiator instead of around it.
Best Regards,0 -
jamcoats wrote:Perhaps I should have made myself a bit more clear. By shrouding it up front I don't mean closing the radiator down to the diameter of a front-mounted fan, as you would do in the rear, but instead installing some simple panels around the perimeter of the radiator to keep air from escaping around the top, bottom, and sides. Force more of the air coming through the grille to go through the radiator instead of around it.
Best Regards,
Jim is right. The propper amount of oil is very important. Too much is bad! The R-134A charge is critical and if you have too much oil, you may have too little freon.
My experience with cooling, The 49 Super has no change to the original fan, no shrouds and no electric fan. Original 47 year old radiator and original core. It cools just fine here in Florida. When idled for 5 minutes or so, It will get up to 205 degrees measured at the outlet of the thermostat . It's never boiled over. Just moving at 35 MPH rapidly cools it down.
The 54 is a little different. Again no change to the cooling system, but runs warmer. Would boil if left to idle 15 minutes or so in 98 degree weather.Normal driving is no problem. Temperature is measured at the same place as the 49. The radiator is a new four core but I don't think it is as efficient as the old original. The problem with the 54 is .. Where in the heck can i install an electric fan? The grille doesn't allow any space, not like the 49 that has lotsa room up front. Maybe a couple small electric fans mounted below the center grille bar? There is no space behind the radiator on any stepdown for an electric or even a multi blade modern fan... Perhaps a properly formed shroud would do the trick? I will experiment with that concept if the cars owner ever comes back from Tennessee.
Keep Kool, Dave W Fl0 -
does anyone have some pictures of these kits installed?0
hudsonkid wrote:okay, looking at some of the units from the links that Rambos posted, are some of these units self contained, and require no compressor mounting?
I had the same idea, about a self contained unit under the dash, with compressor run by an electric motor, using an inverter and high capacity alternator. Called a tech guy at Vintage Air, and he said it won't work- he kept talking about the condenser needs to be outside, etc., etc., but I never could pin him down as to why you couldn't run a compressor with an electric motor. I don't care if you spread the other components around, I just want to get away from hanging a clunky-looking compressor (and even clunkier hoses) in my engine compartment. Anybody have any thoughts?0 -
Mike (WA) wrote:I had the same idea, about a self contained unit under the dash, with compressor run by an electric motor, using an inverter and high capacity alternator. Called a tech guy at Vintage Air, and he said it won't work- he kept talking about the condenser needs to be outside, etc., etc., but I never could pin him down as to why you couldn't run a compressor with an electric motor. I don't care if you spread the other components around, I just want to get away from hanging a clunky-looking compressor (and even clunkier hoses) in my engine compartment. Anybody have any thoughts?
the problem is the 500 or so amps that would be required to drive the compressor.0 -
Let me preface this by saying that I know this question is a little off topic, but I'm just trying to satisfy my curiousity. Does anyone have experience with the Swampy brand coolers? The one that I'm talking about is a unit that uses ice water that is pumped from an ice chest (located in back seat or trunk) through a portable fan/coil arrangement you can place in the front seat area. I would assume that cooling may initially be satisfactory but would drop off significantly as the temperature of chilled water increased. I've run across a few people at cars shows using them that claim these units to be a quick and more economical alternative to conventional A/C. But then again, they may be covering up for a purchase faux pas. Any opinions?0
SuperDave wrote:Jim is right. The propper amount of oil is very important. Too much is bad! The R-134A charge is critical and if you have too much oil, you may have too little freon.
The bigger issue than too little refrigerant is, well, too much oil. Too much oil is worse than too little oil. This is because you can't compress a liquid. Too much liquid in the system and you will turn your compressor into a paperweight.
Another thing to keep in mind, is that with refrigerant capacity, you are looking for a reasonably broad "sweet spot". Too much refrigerant will result in decreased performance just as too little refrigerant will. Too little refrigerant and you'll lose heat transfer capacity. Too much refrigerant and you'll be asking your compressor to compress more than it can, resulting in a higher low-side reading, which is directly proportional to cooling output.
Best Regards,0 -
Dave53-7C wrote:Let me preface this by saying that I know this question is a little off topic, but I'm just trying to satisfy my curiousity. Does anyone have experience with the Swampy brand coolers? The one that I'm talking about is a unit that uses ice water that is pumped from an ice chest (located in back seat or trunk) through a portable fan/coil arrangement you can place in the front seat area. I would assume that cooling may initially be satisfactory but would drop off significantly as the temperature of chilled water increased. I've run across a few people at cars shows using them that claim these units to be a quick and more economical alternative to conventional A/C. But then again, they may be covering up for a purchase faux pas. Any opinions?
Never work here!
Jay0 -
nick s wrote:the problem is the 500 or so amps that would be required to drive the compressor.
I guess what I need to find out is the wattage needed to run the compressor. What got me thinking is that my 120 volt, 2000 watt generator easily runs the rooftop air conditioner on my RV, which probably has more capacity than necessary to cool a car. If its using 1500 watts, that's not out of the question for a 1xx amp, 12 volt alternator (inverted to 120 volts, so the wires don't have to be huge). Guess I need to start looking at data plates on these units to see what is needed to run them.0 -
jsrail wrote:Never work here!
Jay
Actually, I think it would work in arid Arizona, better than in humid climes, so long as you had a diligent dwarf in the trunk, faithfully shoveling ice into the unit. In either case, as soon as the ice is melted, the cooling is over, but as long as you have ice water, the temp would be 32 degrees, and it would be refreshing in Arizona (adds a little humidity) as opposed to Louisiana (sticky just got stickier). But you gotta keep the unit iced. Kind of like some old soft drink ads in the northwest (the name of the soft drink escapes me), which contained "your 5 minute wolf training lesson". Crux of the lesson is that "to train your wolf, throw him meatballs. Never run out of meatballs."0 -
Dave53-7C wrote:How about the evaporative/swamp coolers? Do people still use those in houses there?
Yeah Dave, there still around, in fact I have one on my roof. Never use it though. You used to be able to use swamp coolers until about the beginning of July, but now our summers are getting hot so early they don't work. This year we had 114 in early May! An evap cooler won't get your house below 95 degrees with that heat. Even at 7% humidity. I put 2 new HVAC/Furnaces on my house last summer and how sweet! And you definately gotta have a/c in your car! It can get over 150 degrees inside a car w/ the windows up parked outside in the sun. Its 8:45pm now and its 98 degrees w/ 29% humidity (I know, quite whining....buts its humid for us!) and the heat index is 101 degrees. Our overnight low should be about 85 degrees.
The problem w/ ice here is that it melts before it can do any good! I'm going with a/c, just don't know which company yet, but you guys have given some good info. I think I could get away with a front unit only (w/ a coupe), but do you guys think I should get a rear air? I hate a hot car that takes 45 minutes to cool down (my ol' Range Rover a/c stinks). And Mama is ticked that my Hudson interior and my engine/tranny is in the garage and her truck has to be outside! She's talking about buying me a prefab wooden shed/shop so the garage can get cleaned out!
Jay0 -
jsrail wrote:Yeah Dave, there still around, in fact I have one on my roof. Never use it though. You used to be able to use swamp coolers until about the beginning of July, but now our summers are getting hot so early they don't work. This year we had 114 in early May! An evap cooler won't get your house below 95 degrees with that heat. Even at 7% humidity. I put 2 new HVAC/Furnaces on my house last summer and how sweet! And you definately gotta have a/c in your car! It can get over 150 degrees inside a car w/ the windows up parked outside in the sun. Its 8:45pm now and its 98 degrees w/ 29% humidity (I know, quite whining....buts its humid for us!) and the heat index is 101 degrees. Our overnight low should be about 85 degrees.
Jay
Jay,
All I can say is WOW, 8:45 at night and its 98 degrees! I see what you're saying about the old swamp coolers. Good thing you have new cooling units. I remember that when I used to be in Arizona every summer, swilling down ice cold Coors beer before we could get it east of the rockies, way back in the 60's and 70's, even 20 year old vehicles there had A/C. It's been brutally hot just about everywhere this summer. If this is part of global warming, you'd better get a dual evaporator set up or at least one honkin' evaporator. If you have a wrecking yard nearby that has some old (70's era for example) Cadillac limos, check out the dual A/C system they used. One compressor (a big Harrison A6 workhorse) serves two (front and rear) evaporators, each with seperate thermostat and blower. Better yet, find an old Chrysler that has dual A/C, complete with two compressors. That may give you some ideas of what you want to do. I like your way of getting extra storage, cram the garage and make everyone park outside.
Stay cool...:cool:
Dave0
- 103 Hudson 1916 - 1929
- 19 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
