oil pressure sending unit for 1949 hudson
I need to replace the oil pressure sending unit on my 1949 hudson. Does any one have a current part number from NAPA that i could use on my 1949. the hudson mechanical procedure manual states that a drop of oil pressure to aprox. 13 psi will turn on the oil light. You can answer on the forum or e-mail me at bruce 24k@aol.com thank you
Hi. When you came to the Hudson chatroom someone made a suggestion but apparently you left right away. So I'll simply repeat what was said, you might try giving Dave Kostansek a ring for that oil sender. He's listed in the H-E-T roster and advertises regularly in the WTN.0
