Super Six Radiator Mounts
When I removed the radiator from the '26 Coupe (can it really be a year &
a half ago?) there were no cushions under the "ears" that bolt the radiator
to the frame. Some DPO had just bolted it all together metal to metal. Sweet
boy!
Well, the Hudson parts book lists a cushion for the radiator, but gives
no dimensions. I asked several people that had put these cars together and
received opinions ranging from 1/4" through 3/4" for that critical dimension.
The other dimensions were guesswork also. Another problem was the material.
Motor mounts are made of rubber, so this seemed reasonable for radiator
mounts as well, but it must be a stiff rubber as it would not do to have the
radiator wobbling or sagging.
Press Kale of K-Gap solved the material problem. He suggested mud flap
material which is stiff and fabric reinforced. He even had some scraps
available left over from making mud flaps. The mud flap material is a 1/4"
thick which will allow the thickness to be adjusted as required. That sounded
perfect, thanks Press.
I decided on a 2" circular doughnut shape as this fit the "ear" and
looked like it would take the load as well as any other shape I could think
of. I laid them out using a pencil compass and cut them with ordinary
scissors. They came out a little rougher than I like, but that should be
mostly hidden under the ear.
The center hole had me flummoxed for a while. An Exacto knife with a new
#11 blade seemed the perfect tool, but had real trouble cutting the rubber in
a clean predictable way. Scissors were out of the question on a hole only
7/16", so another solution had to be found.
I have a shop cat that sometimes offers some pretty good solutions when I
am struggling with some tough nut or other, and he was watching me that night
with some amusement. Cats are by nature lazy and smart and don't care to go
to much trouble over anything, but do enjoy watching people struggle. Well,
the Moocher had his fill of entertainment for this evening and I was
interrupting his nap with a steady stream of blue language, so he said, "Why
not drill it?"
I was not very impressed with his smart-aleck tone, but I was out of
better ideas. I knew that you can't drill rubber, it's too flexible. The
drill just grabs the piece and spins, but half the prove the Moocher wrong, I
went out and tried it.
Damned if it didn't work. In a couple of minutes, the drill press easily
bored every doughnut. The Moocher said nothing more, but he did were that
superior smug look that comes so naturally to a feline face for the rest of
the evening.
Moocher the smart Aleck
Paul O'Neil, Hudson29@aol.com
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.onelist.com/community/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
Fullerton, California USA
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
boy!
not drill it?"
the evening.
