Re: [HSS] "Marvel"ous News, Geoff
Tom Goodman wrote:
Tom, glad it worked for you, as it did for me. What happens is that>
> Geoff, thanks for your help with the Marvel Carburetor beast. After
> doing all the messing around with calculations, research,
> brainstorms, fretting, stewing, taking apart and putting back
> together, I arrived at what feels like a good result. My '28 no
> longer neither belches clouds of black smoke nor does it smell like
> it is running with the choke on. What I did:
> (1) As you suggested, I reduced the apparent size of the intermediate
> and high speed jets by hanging pieces of wire (#30AWG x 2 in high
> speed and #30AWG x 1 in intermediate)in the hole.
> (2) As you suggested, I reduced the level of fuel in the float bowl.
> This I did by shimming between the cork float and the brass arm with
> some plain old paper gasket material.
> I no longer choke in my own fumes. Thanks
> Tom
> RaceSearch.com is the complete Internet Motorsports and Performance Parts
> Connection! If you love your car, you will love RaceSearch.com, The
> Ultimate in Performance.
> http://click.egroups.com/1/5267/5/_/695705/_/962800363/
> Community email addresses:
> Shortcut URL to this page:
the float gets slightly heavier over the years with a build up of
residue, and slightly "fuel-logged". Together with the lighter
specific gravity of modern fuel the fuel level is actually above the
level of the low speed jet, hence the constant dripping that most
Marvel carbs exhibit. By lowering the fuel level and reducing the jet
size the original fuel-air ratio is restored. Of course there are other
factors to consider as well, such as flapper position and spring
tension, but all things being equal, you should get a good run out of
your modified set-up. Another thing to be aware of, if you have
trouble starting, and idling, with rough running, is the intake tube in
the hot-box. This was originally of ordinary steel tubing, and
eventually rusts through, allowing exhaust gases into the intake tube.
Easy enough to replace - remove the throttle butterfly and shaft, drive
the old tube out, and replace with either copper or stainless. You may
need to cut down the top of the old tube with a hacksaw blade to get it
out of the top part. Also, the exhaust heat is not really required
with modern fuel, so it's probably a good idea to disable this
altogether and put a stainless plate between the flanges of the by-pass
butterfly. Stops corrosion by exhaust gases, of the inside of the heat
exchanger. The flash point of modern fuel is much lower than 1929
stuff, as anyone who has experienced vapour-lock in hot weather will
attest. Have fun,
Geoff.
