Re: [HSS] 29 Hudson engine
----- Original Message -----
To: <HudsonSuperSix16-29@egroups.com>
Sent: Monday, August 07, 2000 9:56 AM
Subject: [HSS] 29 Hudson engine
> Geoff
> Has anyone modified the engine breathing on these engines?
> My engine has 3 small holes in the rocker cover also a hole in the casting
> below the distributer, also the vents in the tappet cover.
> I have seen an engine fitted with the later Hudson engine breather tubes
> on the the tappet covers. Would this work and Keep engine cleaner?
> John
I have seen one engine modified with a flexible pipe from the top of the
crankcase breather to the carb air intake, but the engine was in very poor
condition. The down-side of this arrangement would be a heavy coating of
sludge on the inside of the intake chamber and intake valves. I don't see
any reason to change the '29 set-up, as air going past the top of the
breather tube will effectively purge the crankcase. Possibly modify with a
curved pipe down to bottom of sump level like the Terraplane and later
set-up would minimise fumes inside the engine compartment, but I have never
found it a problem. Theoretically such a breather from the top tappet cover
would help oil mist circulate up to that area, but would it in fact
lubricate anything, or just disappear out the breather? Earlier models
could possibly benefit from a side tappet breather if crankcase pressure
became a problem, but I doubt if it is necessary.
Geoff.
