Re: [HSS] long w.b. 29 H 7-pass. sd.
----- Original Message -----
To: <HudsonSuperSix16-29@egroups.com>
Sent: Tuesday, August 08, 2000 10:25 AM
Subject: [HSS] long w.b. '29 H 7-pass. sd.
> Had a guy call me who is working on subject car, in Fresno, Calif.
> area - didn't know it existed. Will try to get serial # for Pete W.
> Been trying to find a rear end for it for 6 mo's. I have an NOS ring
> gear & pinion that I was told was for the '29 when I bought it 10
> yrs. ago, but when took out of box today, find it is for a '27-8.
> Going to call Carl Weber to see if will fit in '29; all I can tell
> from the Parts Lists are that the ratios are slightly different & so
> are parts #s.
> Community email addresses:
> Shortcut URL to this page:
Re the interchangeability of '29 with earlier diffs, the whole nugget
assembly will interchange, but the crown and wheel and pinion was
re-designed, and has different profile and bolt patterns, so you can't fit a
'29 crown wheel onto an earlier carrier. The teeth are wider, and the
ratio, whilst staying the same overall, were 53/12 and 53/13, as against
49/11 and 49/12. This gave more tooth contact and spread the load further,
as the earlier units were prone to breaking teeth, particularly on the
49/12.
Geoff clark.
