Re: [HSS] long storage blues
----- Original Message -----
To: <HudsonSuperSix16-29@egroups.com>
Sent: Friday, August 11, 2000 3:06 PM
Subject: [HSS] long storage blues
> I finally hauled my 26 2 door coach home from 9 years of storage
> (including a trip past dept motor vehicles) in hopes of finding
> time to work on it. I really thought that the fuel system had been
> drained.....wrong... vacuum tank was a mess...fixable but foul
> smelling ... have not adressed the gas tank yet, but I did notice
> moisture on the bottom of it ouch.
> But the big problem is ......the engine (that I plan to repace
> anyway) will not turn over. I oiled the cyls and I can "rock" the
> engine but the water pump shaft appears to be stuck. I've done
> the simple stuff like grease the pump and spray penatrant on it
> but to no avail.. I cannot budge the nut on the front of the water
> pump at all, and don't recall how to remove the assy to repair it...
> could someone give me a little insight on this (either "busting it
> loose" or if necessary removing and repairing it????
> Thanks... Bill
> Community email addresses:
> Shortcut URL to this page:
Bill most likely the pump shaft has rusted an seized on to the bushing.
You should be able rock it back and forth with vise grips on the end of the
shaft where the genertaor coupling is and free it up that way. If not,
remove the timing cover, camshaft sprocket and chain, and, after removing
distributor and oil pump pedestal, take out the three bolts holding the
water pump housing on to the crankcase and remove the pump. This will
allow you to dismantle the pump and overhaul it. you will probably find
the impeller sloppy on the shaft, and the shaft very worn where the packings
are. You can either metal spray the shaft and machine, gas weld with
wearbraze, or machine up a complete new shaft from the gear back and get it
welded on to front of the shaft and gear assembly. Try freeing up with
large vice-grips first though, and spray lots of penetrating oil into the
front and back packings. Remember the rear packing nut is left hand
thread, so you have to wind it the opposite way to loosen - you are
probably tightening it up instead, and this will of course jam the packing
even tighter on to the shaft. Have fun!
Geoff.
