Service Manual paint section
Paul et al: for your Town Sedan for instance:
per "Hudson Reference Sheet No. 36 - August 1929"
for the "Hudson Town Sedan"
lists "Standard", then 2 "No. 1 Option"s & a "No. 2 Option" based on
serial #s as years production proceeded.
Standard from serial #827004 was "UPPER BODY Hudson Std. Blue", then
it lists all the colors with that upper body color for lower body,
belt panel, belt panel stripe, bonnet, wood wheels, wood wheels
stripe, wood wheels flanges, wire wheels, shutter assy., & fenders
splash guards etc.
The "UPPER BODY" in Opt. 1 was "Reseda Green" used between serial #s
867693 & 880414 then Option 1 from serial # 880414 & up was upper
body color Nebraska Green, & opt. 2 was offered beg. with serial #
866721 and up & as in prior paragraph tells what colors for all those
other parts of the car were painted.
So basically you can tell PRECISELY what colors were used or were
available for the body style you have, esp. if a very low prod. such
as the limousine for which there was only 1 color combo offered!
It's in a columned format so easily readable, I just couldn't type it
out in the confines of this page properly or would have done so.
Hope this explains.
splash guards etc.
Hope this explains.
