Essex info in Service Manual
Gentlemen - In lieu of several posted messages & several tele. calls
from some of you am going to post what is in the Manual in re Essex:
1.Wiring Diagrams showing: a. "Diagram 1. Bendix Starter. One
Terminal on Generator." etc. b. "Diagram 2. Manual Shift Starter.
Two Terminals on Generator". c. "Diagram 3. " " "
with a 9 point switch" d. "Diagram 4. American Bosch System". Now
the above is on 1 dbl. sided sheet shown on the motor.
2. "Essex Six Front Axle" inc. illus. + adj. brgs. & align front end.
3. rear axle & spring with illus., about 10 pps.
4. steering with illus., 3 pps. & "Super Six Steering Gear"
5. clutch with illus. & " " " Clutch"
6. trans. " " & " " " Trans."
7. pedal control with illus.
8. hand " " " & " " " Hand Control"
9. "Universal Joints & Propeller Shaft" with illus.
10. carb. + "Essex Refererence Sheet No. 10. - (March 1926)
covering "Carburetor Inspection", "The Piston", & "The Packing
Gland". Also a 1 p. update from a N.Y. dealer dated Mar. 21, '29 on
plugs, valve clearance, & ign. + 3 more undated sheets from Hudson
titled "TUNING THE ESSEX CHALLENGER FOR MAXIMUM POWER AND
PERFORMANCE"
11. motor with 3 pps. of illus. + Sept. '29 dealer letter on adj.
noisy timing chains & a "Timing Chain Guide" which can be put in.
12. the i.d. section has serial #s for Essex 4 & 6 (to '25 ?).
13. Essex paint info: Essex sedans, serial #s 475,425 to 500,000, 3
color combos. Essex coach, serial #s 100,000 to 500,000, 5 color
combos. Essex cp. serial # 500,000 up only 1 color combo. Several
pps. on uph. used with various body styles & paint colors. Then
for '29 Essex coach with std. & 4 options, coupe, std. & 4 options,
conv. cp. std. & 4 options, phaeton has 2 std. colors depending on
serial #, rd. std. & 4 options, std. sd. std. & 4 options, town sd.
std. & 4 options, & lastly Dover with only a std. color avail.
14. '26 E spec sheets, 7 pps. with 1 col. for H, other for E
15. '27 E " " , " " just E, no H + some body stuff
16. '28 E " " , 6 " " " " " "
17. '29 E " " , " " " " " " " inc. Dover
PERFORMANCE"
