Re: [HSS] Essex info in Service Manual
Thank you Pete
--- Pete Booz <oldhudsons@aol.com> wrote:
http://www.onelist.com/community/HudsonSuperSix16-29
> Gentlemen - In lieu of several posted messages
> & several tele. calls
> from some of you am going to post what is in
> the Manual in re Essex:
> 1.Wiring Diagrams showing: a. "Diagram 1.
> Bendix Starter. One
> Terminal on Generator." etc. b. "Diagram 2.
> Manual Shift Starter.
> Two Terminals on Generator". c. "Diagram 3.
> with a 9 point switch" d. "Diagram 4.
> American Bosch System". Now
> the above is on 1 dbl. sided sheet shown on the
> motor.
> 2. "Essex Six Front Axle" inc. illus. + adj.
> brgs. & align front end.
> 3. rear axle & spring with illus., about 10
> pps.
> 4. steering with illus., 3 pps. & "Super Six
> Steering Gear"
> 5. clutch with illus. & " " "
> Clutch"
> 6. trans. " " & " " "
> Trans."
> 7. pedal control with illus.
> 8. hand " " " & " " "
> Hand Control"
> 9. "Universal Joints & Propeller Shaft" with
> illus.
> 10. carb. + "Essex Refererence Sheet No. 10. -
> (March 1926)
> covering "Carburetor Inspection", "The Piston",
> & "The Packing
> Gland". Also a 1 p. update from a N.Y. dealer
> dated Mar. 21, '29 on
> plugs, valve clearance, & ign. + 3 more undated
> sheets from Hudson
> titled "TUNING THE ESSEX CHALLENGER FOR MAXIMUM
> POWER AND
> PERFORMANCE"
> 11. motor with 3 pps. of illus. + Sept. '29
> dealer letter on adj.
> noisy timing chains & a "Timing Chain Guide"
> which can be put in.
> 12. the i.d. section has serial #s for Essex 4
> & 6 (to '25 ?).
> 13. Essex paint info: Essex sedans, serial #s
> 475,425 to 500,000, 3
> color combos. Essex coach, serial #s 100,000
> to 500,000, 5 color
> combos. Essex cp. serial # 500,000 up only 1
> color combo. Several
> pps. on uph. used with various body styles &
> paint colors. Then
> for '29 Essex coach with std. & 4 options,
> coupe, std. & 4 options,
> conv. cp. std. & 4 options, phaeton has 2 std.
> colors depending on
> serial #, rd. std. & 4 options, std. sd. std. &
> 4 options, town sd.
> std. & 4 options, & lastly Dover with only a
> std. color avail.
> 14. '26 E spec sheets, 7 pps. with 1 col. for
> H, other for E
> 15. '27 E " " , " " just E, no H +
> some body stuff
> 16. '28 E " " , 6 " " " "
> 17. '29 E " " , " " " " "
> " " inc. Dover
> Community email addresses:
> Subscribe:
> HudsonSuperSix16-29-subscribe@onelist.com
> Unsubscribe:
> HudsonSuperSix16-29-unsubscribe@onelist.com
> List owner:
> HudsonSuperSix16-29-owner@onelist.com
> Shortcut URL to this page:
>__________________________________________________
Do You Yahoo!?
Yahoo! Mail
