Re: [HSS] Didn know his own strength!
John Lawton wrote:
I have stressed this several times over the years, that EVERY steering>
> Aargh!
> I have previously commented that the steering on my '28 Hudson is very
> heavy - well the other day I was moving the car out of the garage, and the
> steering seemed particularly heavy, and... the steering wheel hub casting
> shattered into several pieces!
> It certainly doesn't look to be very good casting, but I couldn't believe
> it would break! Before the failure I had noticed that had been some free
> play between the hub and the shaft.
> I have clearly got a serious problem with the steering, and I think that I
> will have to strip down the wheel swivel joints etc, because the steering
> is light when the wheels are off the ground. It has occurred to me that the
> swivel bushes may have congealed grease in them, hence the stiffness, or
> then again there may be a problem with the steering box.
> In the meantime can anyone help me in finding a new steering wheel hub?
> John
> Community email addresses:
> Shortcut URL to this page:
wheel hub should be replaced, regardless of how good it looks, as this
old pot-metal casting is a disaster waiting to happen. I have re-cast
these out of alloy, using the original as a pattern. For '28 and '29 I
can get these done here, but would probably more economical for you to
get them done in U.S. and save on postage. Cost is around $50 each,
plus machining and postage.
