"1921 Model O & 1922 Super Six Motor Generator No. 188"
Peter - here's what it has & hope this is some if not all of what you
need:
Stall Torque - 8 ft. lbs, 3.1 volts at motor
No Load Test - 60 Amperes at 6 Volts
Motor Brush Spring Tension - 1 3/4 - 2 1/4 lbs. on each
Generator Test - Hot: Cut-in 440 r.p.m. Maximum 16-18 amperes at
1300 r.p.m. Average output required, 15 amperes Note: Above
readings taken at generator. Readings at ammeter on dash will be 2
amperes lower. If generator is tested COLD, add 3 amperes to above
readings.
Generator Spring Tension - 1 1/2-1 3/4 lbs. on each.
There are other paragraphs on: "Bearings & Lubrication", Operation
as a Motor", "Operation as Generator", "To Adjust Charging
Rate", "Rotation While Generating", & " To Remove" which I assume you
don't want/need - if so let me know. There is also a 1 p. wiring
diagram.
This winter promise I'll learn how to send scans to Files section in
here (as well as Hudson 8 site)!!!
need:
readings.
diagram.
