CORROSION IN S-V HEADS & BLOCKS
All,
The guys who will be doing the engine for my racer tell me that the
nature of the alloy used in the side-valve engines (Block and head)
makes it prone to corrosion. Seems it was a steel/cast iron
combination and the steel component rusts. The consequence of this,
they say, is that (a) sleeving the block would be a very good idea
and (b) casting up a new head would make sense because local
(Australian) experience is that when you increase the compression
ratio the combustion chamber will fail due to the rusting from within
the waterways.
I have no problem with sleeving, but the prospect of creating a new
head sounds expensive!
As my direct experience with these engines is zero, I have several
questions for our group:
** Is the above story regarding the metallurgy correct?
** Are other people with s-v engines facing or experiencing this
problem?
** If we in Australia were to produce a new head (probably in
aluminium and with Ricardo-style combustion chambers) would others be
interested in taking up some of the production? Price (completely
unknown at present) would obviously be a factor, but our exchange
rate is so bad right now - US$1 buys AUD$1.87 - that it could be a
bargain!
Maybe this has all been done before. I'd appreciate hearing from the
group.
Thanks.............Peter R.
the waterways.
problem?
bargain!
group.
