Re: [HSS] CORROSION IN S-V HEADS & BLOCKS
Hi Peter,
Well, having worked with gas and diesel engines
for years I never heard that one
The only problem I've heard about with Hudson
engines was the aluminum head (which anybody that
used them had). That is a case of disimilar
metals which could cause the head to literally
weld itself to the block.
Almost seems to me the fellow is trying to sell
an expensive sleeve job - and I've never heard of
a Hudson engine yet that needed sleeving.
But then what do I know.
Alex Burr
--- Peter Ransom <peter.ransom@iint.com> wrote:
http://www.onelist.com/community/HudsonSuperSix16-29
Alex Burr
> All,
> The guys who will be doing the engine for my
> racer tell me that the
> nature of the alloy used in the side-valve
> engines (Block and head)
> makes it prone to corrosion. Seems it was a
> steel/cast iron
> combination and the steel component rusts. The
> consequence of this,
> they say, is that (a) sleeving the block would
> be a very good idea
> and (b) casting up a new head would make sense
> because local
> (Australian) experience is that when you
> increase the compression
> ratio the combustion chamber will fail due to
> the rusting from within
> the waterways.
> I have no problem with sleeving, but the
> prospect of creating a new
> head sounds expensive!
> As my direct experience with these engines is
> zero, I have several
> questions for our group:
> ** Is the above story regarding the metallurgy
> correct?
> ** Are other people with s-v engines facing or
> experiencing this
> problem?
> ** If we in Australia were to produce a new
> head (probably in
> aluminium and with Ricardo-style combustion
> chambers) would others be
> interested in taking up some of the production?
> Price (completely
> unknown at present) would obviously be a
> factor, but our exchange
> rate is so bad right now - US$1 buys AUD$1.87 -
> that it could be a
> bargain!
> Maybe this has all been done before. I'd
> appreciate hearing from the
> group.
> Thanks.............Peter R.
> -------------------------- eGroups Sponsor
> Community email addresses:
> Subscribe:
> HudsonSuperSix16-29-subscribe@onelist.com
> Unsubscribe:
> HudsonSuperSix16-29-unsubscribe@onelist.com
> List owner:
> HudsonSuperSix16-29-owner@onelist.com
> Shortcut URL to this page:
>__________________________________________________
Do You Yahoo!?
Get Yahoo! Mail - Free email you can access from anywhere!
http://mail.yahoo.com/
