Re: Hudson carb.
Peter- Just got off the phone with The Carb Shop in Missouri, I talked
with John (the owner) and he seems quite knowledgeable. He says he has
three of the Hudson carbs in stock, and four of the Essex in stock.
They were made by the Detroit Lubricator Co. for Hudson, and very
simular to the S U carb used on many other makes. He can make up a carb
kit at a cost of $125.00 + $100.00 shipping. It would take about 6 - 10
weeks. The cost of the carb (as is) not a rebuild, would be (are you
sitting down) $800.00 + $200 to $300 shipping each. Sounds like an
expensive way to go ! He also mentioned that there were two
different versions of both the Hudson and the Essex carbs, but couldn't
put his finger on what the they were, because he hasn't looked at them
in years. He would have to compare them to what you have.
I will keep a eye out for some less expensive carbs for you. It would
seem that within our group we would be able to come up with the carbs
you need without mortgaging your home. I hope this info helps. Let me
know if I can do more.
