Re: [HSS] Generator Cut Out
Tom Goodman wrote:
Tom, your best and easiest bet is to replace with a 12 volt cut-out. >
> Patient: 1928 Hudson with 1929 Engine and Autolite CAB (could be GAB)
> 3-brush Generator that has been rewound to output 12 Volts.
> Symptom: Cutout relay (no part number visible) has open-
> circuited "voltage coil" (the fine wire coil wound under the "current
> coil". Therefore, it does not pull in even though the generator is
> putting out proper voltage. I have measured the voltage coil with an
> Ohmmeter and it IS open circuited.
> What I suspect: Since the cutout always seemed to run hot, I suspect
> that it is just a 6 Volt device that has simply been adjusted to pull
> in at a higher voltage (maybe a stronger spring) and, due to the
> extra current through the voltage coil, finally either burned the
> coil out or melted the solder at one end or the other.
> What I want: Does anybody know of someone who repairs (rewinds the
> coil and adjusts the cutout for the proper operating voltage) these
> parts, or does anyone have, or know someone who has, rebuilt or
> exchange cutouts for 12 volts that will fit the application? I think
> that the main issue would be the screw holes to fit on the generator.
> Thanks,
> Tom Goodman
> Community email addresses:
> Shortcut URL to this page:
There are generic ones of these available, and they have slotted
mounting brackets. I'll check out our V.C.C. parts shed, but I'm sure
you could find something over there.
Geoff.
