Re: [HSS] 29 throut thrust washer
Steve Welzbacker wrote:
Steve, the throwout assembly has a collar at the rear with thrust pads>
> We are trying to assemble trans on to F-head. Throut bearing is in
> the presure plate and pushes against the clutch on one side. The
> forks from the clutch pedal do not run on the throut bearing. There
> must be a throut thrust washer? This would push on the clutch pedal
> forks on one side and throut center on the other side? We looked for
> all over the garage last night but could not find it. And
> suggestions on where to find one? Thanks. Hudsonly Steve & Pete
> Community email addresses:
> Shortcut URL to this page:
where the fork sits. The bearing sits inside the assembly, with a horn
shaped fitting at the front. The assembly fits over the front
protrusion of the transmission front bearing housing. You are
obviously missing the rear part of the assembly. Is this a
re-assembly, or something you are putting together from scratch? If a
re-assembly it must be around somewhere surely. It's not sitting on the
transmission is it??? I may be able to find one somewhere if nobody
over there can come to light. Keep in touch.
Geoff Clark
