Fw: "New" 26 Motor Has Arrived But . . .
----- Original Message -----
To: <Hudson29@aol.com>
Sent: Monday, November 20, 2000 9:24 AM
Subject: Re: "New" '26 Motor Has Arrived But . . .
> Paul, it seems your trip went well but you are unhappy with the "new"
motor
> for your car and that is a shame.
> You failed to mention how you finally got the motor running at long last
> just last Sunday. Was it a condenser? or some other ignition problem. It
> is true you can shove your car down a hill or crank start it but no hill
> will start a car that has an ignition problem. I was impressed to see that
> Jack was able to "hot wire" a distributor ment for the famed Elecrolock
anti
> theft device. We must remember that we are working with 70 year old parts
> and even a NOS condenser or coil for example can go bad without notice.
> When this engine was "new" three years ago at the Rapid City National it
> looked and ran empressivly but time is not always kind to mechanical
> machines, especially when not being used. You know the saying "use it or
> lose it" Perhaps it would have been better for both of you (and the
engine)
> if Jack did not let the payments go on for so long
> A re-tourqe may cure your problem but if not DO NOT use the same gasket
and
> I spray paint the gasket silver to help it seal.
> Chris
> 28Hud
