Re: [HSS] Headgaskets Blown/Not Blown . . .
Hudson29@aol.com wrote:
Paul, my '28 Essex has leaked a small amount of oil out the side of the>
> About the leaking head gasket in the '26 Hudson Jeff said:
> << I would try and retorque it before I pulled the head. Also, you will want
> to check the oil and sparkplug to make sure the water is not getting to the
> oil pan or the cylinders. >>
> I had always thought of headgaskets as either good or blown - is it
> possible that a slightly leaking gasket can be sealed by tightening the head
> nuts? I have no problem trying it, but if the gasket leaked under load, won't
> it give way under use. Hudson issued no torque specs, what figure should I
> use? This motor has no washer under the nuts - aren't they required for
> reliable figures?
> NEW email list for Hudson Super Six Cars, 1916-1929!
> http://www.onelist.com/subscribe/HudsonSuperSix16-29
> 1926 Hudson Anderson Bodied Coupe
> 1926 Hudson Parts Car "The Grapes Of Wrath"
> 1928 Hudson Roadster Project
> 1929 Hudson Town Sedan
> 1939 Cadillac Coupe (How'd that get in there?)
> Fullerton, California USA
> AEROMARK - Need Rubber Stamps or Signs? See:
> http://www.aeromark.net
> Community email addresses:
> Shortcut URL to this page:
cylinder head gasket for the last 15 years, and there is no sign of
water in the oil, so I guess I have been lucky that things have not got
worse. Probably an imperfection in the block or head, or even the
gasket. There were no washers installed under the head nuts
originally. Torque the nuts down to 60-65 lbs and see if they move,
you've got nothing to lose.
Geoff.
