How Much Leakage Is Too Much?
As an unscheduled day presented itself, I spent a little time torqueing
the cylinderhead nuts on the '26 side valve Super Six. The gasket between the
block and the head has a small wet spot, maybe two inches long just about
equal with the No. 5 cylinder on the left side. The spot had been bubbling
away merrily with tiny little bubbles like the ones in a good gin & tonic.
First I torqued the nuts to 50 lbs cold and found some considerable
movement on some of them. Another round to 60 lbs produced more movement.
With the help of a cardboard in front of the radiator, the motor was
carefully and lovingly warmed up. (Actually, it boiled while I was distracted
talking birding tactics with the cat.)
Well, now that it was good and hot, I torqued it again, and this produced
some significant movement on some of the nuts. After another restart (and
radiator refill), the bubbling has been cut to almost, but not quite nothing.
I'm going to let it cool some and then go tackle it again to see if there
might be more improvement. Assuming that there is still SOME leakage, the
question arises as to how much is too much. The tiny bit of coolant loss
doesn't worry me, but coolant contamination and mating surface rust does. I
have been told that exhaust leaks into coolant can produce a corrosive
solution.
It is very easy to get to the motor to work on it now, but I hate to
waste a new headgasket if I don't need to as they are getting rather scarce.
The motor is mounted on a test stand and the leak is evident at idle with no
load. I can only fret that under heavy work like pulling a long hill in top
gear that the leaking might be worse, although I sure don't know how to prove
it!
What do you think? Should I have the head off and do it right while it's
out in the open, (although even installed in the car wouldn't be too bad), or
just wait and see if it stops on it's own?
Paul O'Neil, Hudson29@aol.com
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.onelist.com/subscribe/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
Fullerton, California USA
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
solution.
it!
