Re: [HSS] Super Six Gearlever
Hudson29@aol.com wrote:
***Nickle plated. What do you mean ""butler"" finish?
> As the time gets nearer to install the "new" motor in the '26 Coupe,
> there are a few issues to resolve that I hope someone might know the answer
> to. The gear lever on the Coupe needs replating. Does anybody know if it was
> originally finished in bright nickel or in butler finish?
> How does it come off the car? It looks like the dust cover is held on by***The cover is held on by a taper pin. There is a lock wire through
> a pin and can be readily removed. The lever looks to be held into the top of
> the gearbox by a threaded ring with a segmented crown for some sort of
> special tool.
> What can I use to remove the ring? Is there any more to it?
the pin and screw cap. Take this out and the ball cap just unscrews by
hand usually.
How does the
> propellor shaft come undone at the back of the transmission? It looks to have***The joint just unbolts at the flange. Don't unscrew the ferruled
> some sort of ball cover to keep lube in the U-joint. If I unbolt the cover,
> does the connection have some sort of splined shaft like a modern box?
seal cover from the rear or slide the joint off the shaft unless you
first of all not the position of the arrows on the shaft and spline,
otherwise you will get hem back in the wrong position, which leads to
vibration and wear. The covers are held on by round head cap screws.
>Watch out for the key that the shaft goes through. This is all
described in the '26 workshop manual. It's pretty simple really, once
you have done it!
Geoff.
> NEW email list for Hudson Super Six Cars, 1916-1929!
> http://www.onelist.com/subscribe/HudsonSuperSix16-29
> 1926 Hudson Anderson Bodied Coupe
> 1926 Hudson Parts Car "The Grapes Of Wrath"
> 1928 Hudson Roadster Project
> 1929 Hudson Town Sedan
> 1939 Cadillac Coupe (How'd that get in there?)
> Fullerton, California USA
> AEROMARK - Need Rubber Stamps or Signs? See:
> http://www.aeromark.net
> Community email addresses:
> Shortcut URL to this page:
