Super Six Gearlever Butler Finish
Geoff writes that the gear lever was originally finished in nickel and
asks:
<< What do you mean ""butler"" finish? >>
Butler Finish is a type of nickel plating that had a matt appearance. It
was very, very common on upscale sedans in the twenties, even the upscale
Model As used it. My '29 Super Six Town Sedan should have it but it was
redone in chrome by somebody in the past. Many of the Super Six sales
brochures mention that the interior trim in done in butler finish but neglect
to call out which pieces were bright nickel and which were butler finish
nickel. The gear lever being such a large and visible piece is important to
get right. Any opinions?
<< ***The cover is held on by a taper pin. There is a lock wire throughasks:
> How does it come off the car? It looks like the dust cover is held on by
> a pin and can be readily removed. The lever looks to be held into the top of
> the gearbox by a threaded ring with a segmented crown for some sort of
> special tool.
> What can I use to remove the ring? Is there any more to it?
the pin and screw cap. Take this out and the ball cap just unscrews by
hand usually. >>
This turned out to be very easy. The cap did unscrew by hand on the parts
car lever kept in outdoor storage. There was another pin through the
gearlever tower on the '26 parts car. It was retained by a snap pin on each
side, There was also a square spacer part in the vertical cut out on the ball
part of the lever. It was pierced and retained by the pin. Any idea what this
does?
I believe that the coupe should be just as easy when I get to it
hopefully in two days time. I painted the parts car lever black intending to
use it on the Coupe while that lever is at the platers.
> How does thehave
> propellor shaft come undone at the back of the transmission? It looks to
> some sort of ball cover to keep lube in the U-joint. If I unbolt the cover,<< ***The joint just unbolts at the flange. Don't unscrew the ferruled
> does the connection have some sort of splined shaft like a modern box?
seal cover from the rear or slide the joint off the shaft unless you
first of all not the position of the arrows on the shaft and spline,
otherwise you will get hem back in the wrong position, which leads to
vibration and wear. The covers are held on by round head cap screws.
Watch out for the key that the shaft goes through. This is all
described in the '26 workshop manual. It's pretty simple really, once
you have done it! >>
I have that manual and will give it a look this evening, thanks for the
reminder!
Paul O'Neil, Hudson29@aol.com
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.onelist.com/subscribe/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
Fullerton, California USA
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
