Re: [HSS] Exhaust Joint/Clutch Pin
Hudson29@aol.com wrote:
***Whatever you do, don't try hammering this out, it will break the lugs>
> As the time to install the motor in the '26 Coupe is now down to a couple
> of days, there are still a couple of questions to resolve.
> The Coupe has a '29 motor in it now and it will come out to make room for
> the sidevalve. The exhaust pipe has a screw fitting to hold the pipe into the
> cast iron manifold. What do you remove this with? It has a ring with teeth in
> it that looks to be made for a special tool. I sure don't want to break the
> manifold!
off. there was special C-wrench with a lug that fits in the
corresponding lugs in the flange, but in my experience if it won't
unscrew the only way is to heat the manifold several times to a dull
red, let cool, and eventually it will unscrew. The best way id just
cut the exhaust pipe off below the flange and then re-weld the pipe back
on when you install the motor. if you can bring yourself to go
non-standard, weld a bolt type flange on to your manifold, then you
have no future problems. A cast-iron-nickle arc welding electrode is
available for welding steel to iron, and I have successfully done many
of these
> I understand that the clutch is "pinned" on rather than splined on. From***To remove the '26 multi-plate clutch and transmission you have to
> a practical standpoint, how is it assembled/disassembled? The transmission is
> '26 with the locking gearlever, but the motor is '29. I don't know which
> clutch is in it now, but it seems to work well so I would just like to use it
> as is.
unbolt all the clutch cover bolts and bell housing bolts and take
off. You can then fit the '26 flywheel to the original motor and bolt
it all up, (or just bolt it on if the flywheel is already on the new
motor.)
> The car has not been driven for more than a year and the clutch is***No, but if you flush it out and fill with new A.T.F. you should
> certainly stuck. The only way I know to free it is to start it in gear with
> the clutch depressed and hold it with the brake. Does anybody have any
> gentler ideas?
eliminate thes problem. Also, when you turn the engine off each time,
push the clutch pedal in before you turn the engine off, and then let it
out when the engine stops, and this will let a little oil in between the
surfaces to help it not to stick next time.
>Answers inserted above marked *** Geoff
> NEW email list for Hudson Super Six Cars, 1916-1929!
> http://www.onelist.com/subscribe/HudsonSuperSix16-29
> 1926 Hudson Anderson Bodied Coupe
> 1926 Hudson Parts Car "The Grapes Of Wrath"
> 1928 Hudson Roadster Project
> 1929 Hudson Town Sedan
> 1939 Cadillac Coupe (How'd that get in there?)
> Fullerton, California USA
> AEROMARK - Need Rubber Stamps or Signs? See:
> http://www.aeromark.net
> Community email addresses:
> Shortcut URL to this page:
